oil leak
DODGE TRUCK
BUTCHM
I have a 1979 Dodge 150 power wagon it is a 4 wheel drive and has a 318 engine the milage is high but i am not sure how high. I just replaced the rear main seal and the oil pan gasket and the oil filter. The truck just started spuing oil when i replace the brake booster vacume valve(the plastic and rubber). Do you know what could possibly be going wrong?
Jun 11, 2007 at 10:26 PM
SERVICE WRITER
  • 9,123 POSTS
Check for a restriction in the pcv system. Make sure there is vacuum at the valve.
Jun 12, 2007 at 6:19 AM
BUTCHM
SOme one told me it might be my oil sening unit is that sound like it could be the problem?
Jun 13, 2007 at 1:59 PM
SERVICE WRITER
  • 9,123 POSTS
It is certainly a possibility. You still need to make sure the pcv system is working or it will keep creating oil leaks. The pcv system reduces pressure. If it is plugged it will create pressure and force leaks. The leaks may be a symptom of the real problem. The heavy oil leak of course needs to be taken care of.
I wouldn't discount the thought of the rear main still leaking as the shaft may be worn too much for the seal.
Jun 13, 2007 at 2:16 PM
