2005 Dodge Truck over heats
2005 DODGE TRUCK
41,000 MILES • V8 • 4WD • MANUAL
GERRY ORR
engine overheats. runing the heater will cool it down. the radiator feels warmer on the right side (facing the engine from the front) than on the left. antifreeze was checked recently in the shop. radiator is full and reservoir is filled to line as well.
Sep 15, 2008 at 1:40 AM
The radiator could be clogged up-it shoud be evenly warm across the radiator-try flushing it don't work. Replace the radiator or get professionally cleaned/gutted.
Sep 15, 2008 at 1:44 AM
GUNSLINGER69
Before going through all the hassle regarding the radiator....I would throw in a new thermostat. It's a cheaper route to solve the problem if that is the issue. If it's "not" the issue, it only cost you like..12 bucks.
Oct 2, 2008 at 9:05 AM
