2005 Dodge Truck battery affect truck computer
2005 DODGE TRUCK
30,865 MILES • V8 • 4WD • AUTOMATIC
SUISLAM
my truck for some reason would not start. everytime i tried to turn it on i hear a clicking noise, im guessing its the alternater, but all the icon lights on the dash is blinking crazy. It continues after i remove the key, then it shuts off after a couple of minutes what should i do? change the battery? is my computer shutting down? please respond..
thank you.
May 10, 2010 at 2:46 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
start with checking all the battery terminals and cables are clean and tight, check earth points are tight, this sounds like a low voltage problem, start here, and if that is OK, get the battery load tested and the alt charge rate checked.
mark (mhpautos)
May 10, 2010 at 3:47 AM
