2004 Dodge Truck high idling over 2000 rpm
2004 DODGE TRUCK
45,000 MILES • 6 CYL • 2WD • MANUAL
CENDERA
my engine is idling high at 200 rpm.
Dec 13, 2007 at 4:53 PM
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Oct 26, 2007 at 4:14 PM
