2001 Dodge Truck transfer case pops out of 4-wheel drive
2001 DODGE TRUCK
16,000 MILES • V8 • 4WD • AUTOMATIC
JIMMYJ20639
My truck will pop out of 4-wheel drive as I accelerate from a stop. This happens when in either high or low. Linkage looks ok. I have a small vacuum leak somewhere on the truck. Could this be related and how does vacuum interact with the transfer case?
Thank you,
Jim
May 17, 2008 at 7:45 AM
MASTERTECHTIM
  • 4,750 POSTS
does the transfer case pop out of 4wd or does the front differential pop out? will it go back in on its own when you lay off the throttle?
May 17, 2008 at 8:51 AM
JIMMYJ20639
[quote:cd2e77d962="mastertechtim"]does the transfer case pop out of 4wd or does the front differential pop out? will it go back in on its own when you lay off the throttle?[/quote:cd2e77d962]
It is the transfer case. It will not go back in on it's own. When I pull back on the transfer case control (4-H) I can feel it trying to engage. It will stay in for a few seconds as I accelerate then I put it back into 2-H then bring it back into 4-H. The handle in the truck will stay in place.
Thanks for your response!
Jim
May 17, 2008 at 5:26 PM
MASTERTECHTIM
  • 4,750 POSTS
jimmy i think you are going to find that the snap ring on the output shaft has broken. this is not the end of the world. are you a little mechanically inclined? remove the rear drive shaft and the rear output housing on the transfer case, its held in by 4 bolts. pop the cover off and look at the shaft and see if the snap ring is not latched onto the ring on the shaft. replace the snap ring and reassemble
May 17, 2008 at 5:30 PM
