map sensor
2001 DODGE TRUCK
65,000 MILES • 6 CYL • 4WD • AUTOMATIC
RICHSRIDE
where is the map sensor located?
May 23, 2009 at 10:57 PM
BMRFIXIT
  • 19,053 POSTS
Manifold Absolute Pressure Sensor (3.9L)On front of throttle body Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_367.jpg
May 30, 2009 at 5:27 AM
TAZMAN05
Where is the map sensor located on the 5.9L engine?
Dec 19, 2020 at 9:55 AM (Merged)
The map sensor is near the top of the engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/12900_map_2.jpg
TEVERETT
Where is the map sensor located on my 1998.5 Dodge ram 2500 24 valve turbo deisel?
BLUELIGHTNIN6
  • 16,542 POSTS
The MAP sensor is fitted to the front of the throttle body except on 4.7L and 8.0L engines where it is installed on the intake manifold.
Thanks for using 2CarPros.com!
