2001 Dodge Truck Injector / PCM
2001 DODGE TRUCK
TLTFISH
  • 4 POSTS
Electrical problem
2001 Dodge Truck V8 Four Wheel Drive Automatic 100.00 miles
I have checked the wiring back to the PCM now where do I go from here. Oh the wiring was fine, plus I checked the other injectors the all where fine and #3 is barely getting and signal. Am I just going to have to go to the dealership to solve this problem.
Apr 29, 2008 at 9:56 AM
2CARPRO JACK
  • 11,533 POSTS
So does it have 12 volts at the injector? PCM grounds it to make it work. You checked the power feed wire anad the ground side?
Apr 29, 2008 at 12:24 PM
ALIUSV2
  • 9 POSTS
It seems to me that the driver is for the fuel injectors is bad. I doubt it will do much good but try unhooking the connectors from the PCM, unhooking your battery cables and clamping them together for a couple of minutes, plug the connectors back into the PCM and reapplying the battery cables. If it happens again you likely need a new module.
Aug 18, 2008 at 12:04 AM
