When I start my engine it seems to run well. A couple of minutes after it has been running it will sputter/misfire briefly. I put it in neutral and give it gas and the problem goes away and stays away as long as the engine is hot. I replaced the filter/pressure regulator because it started hard also. Now I only have this problem. I have inspected but not replaced the idle air module. Any ideas?
Aug 25, 2010 at 2:03 PM
