AC WAS NOT WORKING BROUGHT IT TO REPAIR SHOP, COMPRESSOR WOULD RUN THEN STOP LIKE IT NEEDED FREON, SHOP ADDED FREON AND LEAK DETECTOR, WORKED FINE FOR A WHILE THEN THE COMPRESSOR STARTED DOING THE SAME THING. BROUGHT IT BACK THEY FOUND A BAD LOW PRESSURE SWITCH. COMPRESSOR STARTED DOING THE SAME THING AGAIN. WHEN THE COMPRESSOR IS RUNNING THE AIR IS COLD THE TUBE NEXT TO THE DEHYDRATOR IS COLD NEVER FREEZES.DOESN'T SEEM TO HAVE A LEAK. COULD IT BE A BAD CLUTCH/
Apr 11, 2009 at 9:14 AM
