1998 Dodge Truck Bad o2 sensor?
1998 DODGE TRUCK
169,000 MILES • V8 • 2WD • AUTOMATIC
MOPAR4LIFE98
  • 5 POSTS
well i cleaned out my throttle body the other day and it threw a code 02 sensor high voltage bank 1 sensor 2 which if i'm not mistaken means downstream sensor after the catalytic converter. i also ran some sea foam through the brake vacuum the clean the motor out but still no fix what does this code mean?
Jan 19, 2010 at 7:27 AM
BLACKOP555
  • 10,386 POSTS
means that the catalytic convertor has possibly failed or the vehicle is reading too much voltage at the o2 sensor. due to bad convertor or a bad o2 sensor.
Jan 19, 2010 at 6:42 PM
