1996 Dodge Truck 1996 Dodge Driveability Issues
1996 DODGE TRUCK
V10VIC
Engine Mechanical problem
1996 Dodge Truck Four Wheel Drive Manual 189900 miles
[img:75da837161]http://www.2carpros.com/forum/automotive_pictures/473508_96_Dodge_1.jpg[/img:75da837161] Hi, I am having some issues with my truck. I have a 1996 Dodge 2500 4x4 - V10 5speed. When I first start the truck it idles fine, but cannot drive it until it reaches operating temp. It sputters, jerks, and is definately running rich. Which by the way is the code that keeps popping up. I have tested the fuel pressure and it is good. Replaced O2 sensors and Air Charge Sensor. All other sensors seem to be fine. I thought maybe a clogged Cat, but it seems before I purchased the truck 3 1/2 yrs ago, someone else had an issue with them and the are gutted. Sorry for such a long post, but this has been driving me nuts the past few weeks. So any and all help would be appreciated. Thanks in advance.
Jan 31, 2010 at 5:50 PM
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Jan 31, 2010 at 6:20 PM
