1996 Dodge Truck
1996 DODGE TRUCK
166,000 MILES • V8 • 2WD • AUTOMATIC
HOGGHARLEY
1996 dodge ram 1500 lost power got towed home my ceck engine was on for a little while autozone said it was my o2 senser bank 1 frt of cat converter after abought 30 start up check engine lie went out then driveing down the road 2 weeks later lost power i check to see how hard it would be to change o2 senser and notice abought 2 inches frm my oil pressure swicth a hole opening with shiney clean threads on the back of my intake manifold 1/2 in threads i bouhgt a pipe plug put it in fiinger tight i did not want strip the threads it starts if i floor it only for a few moments dies out engine is a 5.9 360 motor i bought the truck new it is stock put new plugs and air filter in it any body know what goes in that hole in the intake dodge dealer coulld not tell me so they said bring it in i told them if you cant tell me what goes there how can you fix it if you are lost for words on help i looked at 3 other ram trucks they did not have that hole with threads
Feb 23, 2009 at 8:48 AM
Are you sure the O2 sensor doesn't go there? Does the hole cause an exhaust leak?
Mar 13, 2009 at 1:25 PM
