1996 Dodge Truck
1996 DODGE TRUCK
SHAWNTABKING
Electrical problem
1996 Dodge Truck 6 cyl Two Wheel Drive Automatic
After recently driving through high water, the engine component fuse keeps blowing after only 1 to 2 miles. I have replaced it over 5 times and it continues to do the same thing. Any suggestions on what might be causing this?
May 21, 2010 at 7:50 PM
HMAC300
  • 48,601 POSTS
driving through water and it probably splashed or went underwater as you didn't say how deep it was is the cause. the only thing to do is check al your connections and see if there is anywater anywhere. water really wreaks havoc with electronics. You might let it dry for a while and make sure there is no corrosion on the connectors.
May 24, 2010 at 5:06 PM
