1990 Dodge Truck no spark no start
1990 DODGE TRUCK
JSKIRP
Electrical problem
1990 Dodge Truck 6 cyl Two Wheel Drive 140000 miles
i was driving it backed up a hill shut it off went to start it nothing changed the oil pressure sensor,coil,pick up coil getting no spark from lead wire off coil to distributer were is the crank/camshaft sensors?maybe ignition control module cant find it either or ecm?????????????what could cause this vehicle to get no spark from the coil??/
Aug 1, 2009 at 9:20 PM
Are you getting power to the coil? As far as the crank sensor, it should be mounted to the timing chain cover near the harmonic balancer.
Oct 7, 2009 at 1:04 PM
