EMR MILEAGE RESET (1989-92 LIGHT DUTY TRUCKS & VANS) 1. Using DRB-II tester, select EMR MEMORY CHECK. DRB-II display will read, EMR MEMORY CHECK ARE YOU SURE? Press YES key. 2. Display will read, WRITE TEST. Display will read, IS INSTRUMENT PANEL MILEAGE BETWEEN XXXXXX AND XXXXXX? If odometer mileage on vehicle is within specification, press YES key. DRB-II will display EMR MEMORY CHECK TEST COMPLETE. 3. If odometer mileage on vehicle is not within specification shown on DRB-II, press NO key. DRB- II will read DO YOU WANT TO CORRECT EMR MILEAGE? Press YES key on DRB-II. DRB-II will display ENTER MILEAGE SHOWN ON INSTRUMENT PANEL. 4. Enter mileage shown on instrument panel. DO NOT enter tenths. Press ENTER key on DRB-II. DRB-II will ask for verification of entry. If mileage entry was correct, DRB-II will display SETTING ENGINE DATA and EMR MEMORY CHECK TEST COMPLETE. Vehicle must be driven for at least 8 miles for mileage reset to be accepted. © 2007 Mitchell Repair Information Co., LLC. NOTE: DRB-II may display EMR MEMORY WRITE FAILURE or EMR MEMORY CHECK WRITE REFUSED if there is a problem with SMEC/SBEC. Page 1 of 1 MAINTENANCE REMINDER LIGHT RESET PROCEDURES -1990 Dodge Pickup D1... 9/7/2008
http://www.ondemand5.com/mric/common/asp/printart.aspx
Sep 7, 2008 at 8:55 AM
