1988 Dodge Truck no fuel
1988 DODGE TRUCK
121,000 MILES • V8 • 2WD • AUTOMATIC
JMMAPE
I have a 1988 Dodge d100 with a 318. Had problems with it dumping too much fuel. Replaced fuel pressure regulator, then got no fuel. Replaced fuel pump and filter still getting no fuel to the throttle body. Got pressure at fuel filter
Jun 20, 2010 at 10:59 PM
Is the fuel pressure within specs and are the injectors pulsing
Jun 21, 2010 at 1:07 AM
JMMAPE
Yes, injectors are pulsing and the PSI at the pump is about 17
Jun 21, 2010 at 6:43 AM
Your pressure is lil bit on the high side -check the fuel return line if its clogged this will cause the fuel pressure to rise over the normal specs
https://www.2carpros.com/forum/automotive_pictures/12900_fp_48.jpg
Jun 21, 2010 at 3:15 PM
