when its cold the motor wont idle and runs bad. when its warm out it idles and runs fine throttle body no choke
Dec 27, 2007 at 6:08 PM
MERLIN2021
CERTIFIED EXPERT
Check the operation of the choke, may need to install a new choke thermostat, also check the exhaust manifolds for a heat riser, if it's frozen, either free it up or replace it, this aids in warming the engine, but once warm, it will open and allow exhaust to flow...
Dec 27, 2007 at 6:17 PM
ZEPHYUS
MEMBER
1 POST
What if it's a tbi engine
Dec 19, 2024 at 3:34 PM
CERTIFIED EXPERT
Then you probably have a vacuum leak, please go over this guide which will help you fix it:
