1987 Dodge Truck air condition question
1987 DODGE TRUCK
87,000 MILES • V8 • 2WD • AUTOMATIC
DODG1987
the a/c unit in my 1987 dodge pickup will not work. the compresser works. when i pull a vaccume it holds the pressure but when i put coolant into the system. it dosenot hold the pressure
Jun 18, 2009 at 9:06 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
if the system is holding a vacuum there should be no leaks, you may have a problem with the compressor and leaking internally, has the system pressures be check on charging? or are you just trying a bottle fill ?
mark (mhpautos)
Jun 19, 2009 at 2:21 AM
