1986 Dodge Truck Do I have choke heater resistor?
1986 DODGE TRUCK
134,000 MILES • V8 • 2WD • AUTOMATIC
SHEILASHO
Hello, I have a 1986 Dodge d150 with a 360. I lost a thin 2 inch long resistor type part which had 2 plug-in connectors and sat near the coil. It connected to the same wiring path that went to the electric choke and the temp. sensor. The colors of the wires were basically the same, dark blue with a pink stripe. Is this some kind of resistor for the choke for I do have my ballast resistor. My choke isn't working but funny thing is when I power up the ignition I don't even get any voltage reading from the connectors where that darn little thing plugs into. I hope somebody can help, I can't even find that part on auto part websites. :/
Dec 4, 2007 at 7:03 PM
  • 7 POSTS
I have the same type of '86 - 150 truck with a slant 6, 2wd automatic. I thought the resistor by the coil was for the coil, but another post said the coil resistor is in the Spark Control Module computer. Mine is only about 2" away from the coil on the engine block, connected to the positive of the coil with about 5" of wire and only one connector is connected.
I have a Chilton's manual with diagrams, but it is hard to tell - it looks like a dark green wire comes from the Alternator to the Voltage Regulator, then a dk blue from there to the Oil Pressure Switch, (another dk blue wire leads to the fuse, dash light and back to the Oil Pressure Switch). From the Oil Pressure Switch to the Electronic Choke is a dk blue/red wire which also goes to the Electric Choke Heater, (is this the 'resistor' you're talking about?).. V8 is a little different with the first dk blue splitting after the Voltage Regulator, so you'ld have to follow it to the Oil Pressure Switch.
Also, it kind of makes sense that it would be a part found at a dealer or parts store if it is cheap. Shipping a single part like that could cost more than the part itself.
Oct 15, 2008 at 10:25 AM
