1983 Dodge Truck NO SPARK!
1983 DODGE TRUCK
125,000 MILES • V8 • 4WD • AUTOMATIC
RALPH0470
  • 8 POSTS
I have a 83 Dodge w150 5.2L. I get no spark at all.
Car cranks but obviously doesnt turn.
There were many rusted out parts so here is a list of whats already been replaced within last 2 weeks:
Ignition coil: Twice
Ballaster Resistor
Distributor cap
Spark plugs: set at .035
Spark Plug Wires
Fuel Pump
Fuel Filter
Fuel Line: 5/16
Fuel Sending Unit
Ignition Start Relay
Distributor Rotor
Battery
Ignition Control Module
only thing I havnt replaced is the distributor pickup becuase i'm not sure how to get it out of there. I removed two screws from plate but something else that i cant see is still holding it down. I also have not replaced starter relay just because.
any thoughts?
Oct 24, 2009 at 3:22 PM
SERVICE WRITER
  • 9,123 POSTS
These would be among the possible causes if "no spark". What muddies this up is so many parts were replaced. If you run into a bad part out of the box, you may have a new source for a no start.]
https://www.2carpros.com/forum/automotive_pictures/30961_dodis2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_dodis_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_dodis1_1.jpg
Oct 24, 2009 at 3:40 PM
RALPH0470
  • 8 POSTS
Thanks! I'll check out those readings and keep you posted.
Oct 24, 2009 at 5:28 PM
RALPH0470
  • 8 POSTS
No spark at the coil. I have voltage on the coils + terminal though?
Oct 25, 2009 at 9:06 PM
SERVICE WRITER
  • 9,123 POSTS
Here are some test procedures that may help.
https://www.2carpros.com/forum/automotive_pictures/30961_d150_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_d1507_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_d1501_1.jpg
Oct 26, 2009 at 5:15 AM
RALPH0470
  • 8 POSTS
Hey I was just about to perform all of the recommended steps and noticed something on the fire wall very rusty with a hole in it. Turns out it is a voltage regulator?
https://www.2carpros.com/forum/automotive_pictures/426004_vr733_2.jpg
Could this have anything to do with the no spark issue?
Oct 26, 2009 at 12:51 PM
SERVICE WRITER
  • 9,123 POSTS
Maybe.
https://www.2carpros.com/forum/automotive_pictures/30961_d150_2.jpg
Oct 26, 2009 at 2:23 PM
RALPH0470
  • 8 POSTS
Thank you for the wiring diagram. Is there any way you can provide a larger image. I tried to resize but it is very blury and i cant make anything out.
If this is not an option please provide the source and I'll try to retreive it.
Thanks again,
Ralph
Oct 26, 2009 at 2:38 PM
SERVICE WRITER
  • 9,123 POSTS
check your email
Oct 26, 2009 at 3:17 PM
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_30961_truck1_1_1.jpg
COOL Hood Ornament! Been a long time..LOL Snow is coming, gotta that plow on her soon....
Oct 30, 2009 at 7:38 PM
RALPH0470
  • 8 POSTS
whaaaaaaaaaaaaaaaaa.....
ok i starting putzing around with the + - wires connected to the coil and i finally got a spark. Engine still wont turn over and I noticed the ignition coil is BURNING HOT!. timing seems ok.
I poured a little gas in the carb and heard a LITTLE backfire but engine still wont start up. This is frustrating. Also checked the firing order as displayed in the haynes manual i just bought today and I believe I have it right. The dist. rotor looks to be pointed to plug #1 too.
So two sum up it up:
Getting spark now
Really, really hot coil
engine will not fire or turn over
heard a little backfiring after pouring gas in carb.
and just becuase everything was original and rusty never tuned up or falling off here are the parts replaced:
Ignition coil
Ballaster Resistor
Distributor cap
Spark plugs
Spark Plug Wires
Fuel Pump
Fuel Filter
Fuel Line
Fuel Sending Unit
Distributor Rotor
Battery
Voltage Regulator
Start Run or Pickup Relay
I have not replaced the distributor dual pickup coils.
any additional thoughts before i light the thing on fire and push it off a cliff?
Oct 31, 2009 at 3:05 PM
RALPH0470
  • 8 POSTS
Forget the hot coil issue. Resolved that short at the ballast resistor. Danm thing just wont start. Cranks and cranks. I did notice that I had an orange spark not a real good blue one btw.
Rechecked all the spark plus cables for correct firing order. gettin close to giving up.
Someone!!!!!!!!!
Could I have solved spark issue that was masking a fuel issue now? Carb? Any way to test that?
I know Im all over the place. Sorry.
Oct 31, 2009 at 4:42 PM
RALPH0470
  • 8 POSTS
ok here is the update. after following electrical wires around and replacing several sevaral parts I have a spark now.
Car still doesnt start. I get alot of backfiring from the carb and if I pump the gas enough times while trying to crank the engine the carb spits the gas out.
I verified the firing order and it is correct. Checked the timing and that is correct too.
Any thoughts?
Nov 3, 2009 at 4:12 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like you are flooding it. Pull a couple plugs and make sure they are clean and dry still. IF the the plugs are fouled that may be your last link.
Nov 3, 2009 at 7:23 PM
