I have a 98 dodge stratus 200,000 miles 2.4. I have replaced the head gasket, valves, and water pump, fuel pump and filter, air filter. when i replaced the head gasket there was nosludge in the engine. the check engine light came on. and it said i needed a oxygen sensor and a throttle position sensor. replaced both. check engine light still on replaced throttle position sensor again. check engine light is still on and car will not run well. it dies when I stop at a stop sign and the engine chugs like it is starved for fuel or it hiccups when driving. it usually runs well for about 1 day after I replace the throttle position sensor and then starts having problems. any ideas?
May 18, 2007 at 1:07 AM
