Thermostat placement
2005 DODGE STRATUS
CRICKET68131
Heater problem 6 cyl Front Wheel Drive Automatic 90,000 miles
I am trying to find the exact placement of the Thermostat on my 2005 Dodge Stratus. The heater is not working properly. It is cold air coming out when the heater is on. The heater will warm up some after the engine temperature goes up. the engine temperature does not get above the half way mark. I need to know where exactly the thermostat is located and what kind of problems there could be with the engine. Thanks.
Oct 15, 2009 at 9:35 AM
The thermostat location is at the end of the upper radiator hose inside of the housing on the engine. Here is a guide and a diagram to help you get the job done.
May 10, 2017 at 5:32 PM
JESS1346
where is the thermostat located within the engine?
Oct 27, 2020 at 10:02 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
In thermostat housing, located where the lower radiator hose connects to the engine block.
JAMESSLICK1
  • 5 POSTS
it over heated and it taking the water , but overheating
Oct 27, 2020 at 10:03 AM (Merged)
HMAC300
  • 48,601 POSTS
check for proper tstat install. then check the actuators in your heater i'll send a generic pic along
JAMESSLICK1
  • 5 POSTS
but what do this have anything to do with the overheating?
do the radiator have anything to do with it?
HMAC300
  • 48,601 POSTS
yu may have put yoru tstat in upside down and it won't work
JAMESSLICK1
  • 5 POSTS
no it right, because it was working.
HMAC300
  • 48,601 POSTS
then check the radiator for cold spots AFTER the engine is shut off and warmed up. if you feel cold spots then the rad is bad. Also have it checked for a head gasket/intake gasket leak. Or any broken hoses.
GAIL CRISP DALTON
How do you position the thermostat?
JOETECHPRO
  • 705 POSTS
Hey GAIL CRISP DALTON,
Please see the instructions below on thermostat replacement for your vehicle.
You should be able to see orientation from the picture in the instructions.
Any further questions do not hesitate to ask.
Regards, Joe
GAIL CRISP DALTON
Thank you so much.
JOETECHPRO
  • 705 POSTS
No problem, glad to help. If you have any further questions please don't hesitate to ask.
Regards, Joe
ASTROGIRL9182
In February 2014 I bought a 2004 Dodge Stratus with 46,000 miles. I have since racked up to 87,000 today with my long commute. I've had multiple repairs every 3 or 4 months but mostly the thermostat and gasket. They have been replaced 3 times. First when the whole engine died and was replaced in November. Again in March a month after my heat failed and the heater core was flushed. The idler pulley was also replaced then. The third time was yesterday. Each time at a different shop. This third time the mechanic told me I had missing bolts and wrong pieces all throughout. Too many to list. Reviews I find online for my car and Dodge in general are not good, bottom of the barrel. But it also seems like I have had bad mechanics. Should this car at this age need a thermostat and gasket so often or do I need a better mechanic?
HMAC300
  • 48,601 POSTS
obviously the one that has looked at it last is ok as he has found missing pieces and bolts. no it shouldn't need thermostats that often but maybe because of shoddy work inpast is why. try the last guy to see if he can straighten it out. next time also put engine size in when asking a question. thanks.
TWINKEY1
  • 49 POSTS
Engine Cooling problem 2003 Dodge Stratus 4 cyl i had a little leak on my thrmostat housing,so went to a parts store to get a new Thermostat Housing Gasket,since i was there picked up a new thermostat and it doesnt call for a regular gasket,just the seal,so when i went to put it in it did fit around the thermostat and inside the housing but when i went to put it on the block to tighten it down it seem way to big,seal didnt fit flush in the housing like the old one did,so i decided to go to a dodge dealer to get one but theres the same way,i was told it was an updated seal and it will fit,tighten it and it will compress to make a seal,so was wondering where they updated and should i use it
https://www.2carpros.com/forum/automotive_pictures/221946_getimage_1.jpg
Oct 27, 2020 at 10:04 AM (Merged)
XSHAWN117X
  • 12 POSTS
You shouldn't have a problem. I have that exact seal and had replaced mine a few months ago and haven't had any leaks.
SCHMIEDY11
where is the thermostat in this stratus
Fig. 20 Thermostat and Housing - 2.7L
https://www.2carpros.com/forum/automotive_pictures/12900_t_8.jpg
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
TNW626
where is the thermostat located for a 2001 dodge stratus se v6
The thermostat is located on the lower left near the front. It is on the inlet side of the waterpump. I have attached a picture for you. As far as bleeding the system after the job is done, it has an air bleed on the flange of the thermostat to allow trapped air to exit when refilling.
TNW626
lower left standing in front facing the engine?
Yes, from the front. You will see a large radiator hose going to it and a smaller hose (for the heater core).
I'm glad you emailed back. I reviewed our posts. I wanted to mention to you to make sure the bleeder on the t-stat flange needs to be in the 12 o'clock position.
TNW626
k. thanx
Glad to help.
SHANJANA
where is thermostat located and how do I replace it
ok, it wont show pictures but it is at the end of the upper hose to the cylinder head. easy job.
REMOVAL
WARNING: DO NOT REMOVE PRESSURE CAP WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR.
Drain cooling system to the thermostat level or below.
Disconnect hoses at coolant outlet connector.
Zoom Sized for Print
Remove bolts attaching coolant outlet connector.
Remove coolant outlet connector and thermostat.
INSTALLATION
Clean sealing surfaces.
Place the new thermostat assembly into the coolant outlet connector. Align air bleed with notch on the coolant outlet connector.
Install coolant outlet connector onto thermostat housing and tighten bolts to 12.5 Nm (110 inch lbs.) .
Connect hoses to coolant outlet connector.
Fill cooling system.
DRCCBJR
  • 38 POSTS
Will a car heat without a thermostat?
Oct 27, 2020 at 10:05 AM (Merged)
CARADIODOC
  • 34,306 POSTS
No. The thermostat closes to block coolant flow until the engine warms up. That's when parts expand, fit properly, and the least amount of wear takes place. At about 195 degrees the thermostatic spring opens the thermostat to let the hot coolant flow to the radiator. That hot coolant is what circulates through the heater core in the dash board to provide the heat.
In rare instances an engine lacking a thermostat can actually overheat. That is more likely to happen in summer. After the engine fully warms up, the hot coolant circulates so fast it doesn't stay in the radiator long enough to cool down.
caradiodoc
DAVE MC DONALD
Where is the thermostat located on a Dodge Stratus with a 2.4 engine.
Also the door a-jar keeps going off when the door is shut. Is this a sensor and if so where is it located so i can replace it.
ZACKMAN
  • 4,202 POSTS
Locate your upper radiator hose. Follow that hose towards the engine block. You will see the thermostat housing with two bolts securing it.
One of your door switches is bad. Figure out which one and replace. It is located on the door sill.
