Car won't start; nothing happens when ke
2005 DODGE STRATUS
LEATRICE
Electrical problem 6 cyl Four Wheel Drive Automatic 100,00 miles
My car won't start, when key is turned it will not make a sound. The only unuual thing that happened was that I bumped in to a pole the other day, it was not a very hard jar and it only caused a slight scrape. About an hour later as I was getting ready to leave, the car would not say anything; also the steering wheel was locked and the brakes were locked.
Mar 25, 2010 at 1:59 PM
2CARPRO JACK
  • 11,533 POSTS
Does the dash light up when you turn the key on? If so did it the dash go dark when you tried to crank it? Exactly what do you mean "the brakes were locked?"
Mar 29, 2010 at 3:40 PM
ZELLDOG93
  • 111 POSTS
I have checked ever fuse and relay swapping with known good replacements car was bought at auction last week i cant find wiring diagram for ignition either
Nov 15, 2017 at 10:52 AM
Here is some guides and diagrams to help you do the testing needed to fix the problem. I have engine and ignition diagrams for both engines.
and
Nov 17, 2017 at 1:50 PM
