CHECK ENGINE LIGHT CAME ON, AND CAR STARTED RUNNING ROUGH, SO HAD IT SCANNED AND GOT CODE P0108. IT SUGGESTED THAT IT MAY BE THE MAP SENSOR, HOW CAN I CHECK FOR SURE TO SEE IF THAT SENSOR IS BAD??? I TOOK OFF THAT SENSOR CLEANED IT AND CHECKED ALL HOSES, IS THERE ANYTHING ELSE I MIGHT TRY TO SOLVE THE PROBLEM??? CAR WHEN FIRST STARTED PUTTERS LIKE IT ISN'T GETTING GAS AND SOMETIMES TAKES A FEW TIMES TO START. IT SAYS VOLTAGE TO MAP IS TO HIGH
May 16, 2008 at 9:48 PM
