blower not working?
2004 DODGE STRATUS
DOGG3D897
Heater problem
2004 Dodge Stratus 6 cyl Front Wheel Drive Automatic
my heater at one point would only work on high, i was lazy and didnt replace the blower motor resistor. Now the heater will not work at all and i was wondering if i possibly did more harm to the unit?
thank you
dogg3d897
Oct 16, 2008 at 10:17 AM
JASONRAY
  • 213 POSTS
No, you shouldn't have harmed anything else. It sounds like the blower motor went out here is the location for the blower motor and resistor so you can replace them to get the system working again this guide can help as well.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Check out the diagrams (Below). Please let us know what happens.
Oct 17, 2008 at 4:06 PM
DJT412
so I know the car is getting heat still I am 90% sure it's not the thermostat. I think it's the blower motor that's not working and it's 20 degrees on average right now, anyone know how difficult a job this is to do myself?
Oct 27, 2020 at 10:32 AM (Merged)
ZACKMAN
  • 4,202 POSTS
Does the blower motor run at all 4 speeds? If yes, blower motor works properly. If your heat is only lukewarm, check your coolant level. Should be almost to the "FULL" line. If it is, check the strength of your antifreeze with a unit similar to this
https://www.2carpros.com/forum/automotive_pictures/55316_af1420_2.jpg
. Depending on where you live, your coolant should be more than 20 degrees lower than the coldest night. Next is to replace the thermostat.
DJT412
the blower doesn't work at all on any of the 4 settings, i checked the coolant i know the heat still works it just isn't getting blown out and I already checked the fuse too, any other ideas?
ZACKMAN
  • 4,202 POSTS
Then replace your blower motor, AFTER you check your junction block (left side of dash) fuse #1 30A and #11 10A for 4-door, or fuse #6 30A, #20 7.5A and blower relay for 2-door.
DJT412
thanks alot for the info
FOXRACER1988
my heat in my car wont work it did before but now it wont work you turn the **** to turn it on and you can hear the switch kick on but the fan wont come on and blow out heat i have replace the fan motor but still wont work what could be the problem?
Oct 27, 2020 at 10:33 AM (Merged)
Check the fan relay and blower motor resister. Also, check to make sure there is power to the new motor. Check to make sure there is a good ground to the motor.
