2003 Dodge Stratus Brake Light Switch Wiring
2003 DODGE STRATUS
93,407 MILES • 4 CYL • FWD • AUTOMATIC
PANTHER65
  • 6 POSTS
when I bought my car used someone had cut out the brake light switch wires. I went and got the a used switch from a junk yard that has 6 wires but I only see 4 wires that were cut. how do I wire the switch.
Oct 3, 2010 at 10:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
does your vehicle have cruise control? is it 4 door or 2 door model? if 4 door than brake lamp switch should only have 2 wires, white/tan and red/black.
Oct 3, 2010 at 10:12 PM
PANTHER65
  • 6 POSTS
it has 2 doors and cruise control but it doesn't work
Oct 3, 2010 at 10:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
could you tell me the color of the 4 wires that were cut please
Oct 3, 2010 at 11:34 PM
PANTHER65
  • 6 POSTS
green, yellow, brown and blue
Oct 3, 2010 at 11:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
my wiring diagram is not matching up to what you're describing. are these wires solid colored or do they have a stripe on them? is this a Stratus R/T?
Oct 4, 2010 at 12:05 AM
PANTHER65
  • 6 POSTS
I am sory I was trying to see what the colors were at night. The colors of the wires are green with orange stripe, solid green, yellow and light green, the brake light switch i got from an auto salvage place has 6 wires the colors are black with red stripe, white with gold stripe, white with red stripe, red with black strip, yellow with red stripe, black with green stripe. am I going to use all 6 of these?
Oct 4, 2010 at 5:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
schematic is showing only 2 wires. a green/black wire going to fuse box and a green/orange wire that splits into 3 sections, 1 for cruise control, 1 for ABS and 1 for the brake lights.
Oct 4, 2010 at 8:08 PM
PANTHER65
  • 6 POSTS
checked it again and i see 4 wires that were cut I will try to get a picture of them tonight. one is green with orange stripe no breaking off in sections on this, one is yellow one is light green and the other is green with no stripe. I bought this car used and it came as is. I just want my brake lights to work, I really don't use cruise control. the light always stays on this so i removed the fuse
Oct 4, 2010 at 8:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
ok i might be of more help once i see the pics
Oct 4, 2010 at 8:37 PM
PANTHER65
  • 6 POSTS
here iare 3 pics the last one doesn't go anywhere i don't know what goes in this clip type thing
https://www.2carpros.com/forum/automotive_pictures/579570_DSC01640_1.jpg
https://www.2carpros.com/forum/automotive_pictures/579570_DSC01646_1.jpg
https://www.2carpros.com/forum/automotive_pictures/579570_DSC01647_1.jpg
Oct 4, 2010 at 9:23 PM
BLACKOP555
  • 10,386 POSTS
green and black is power. it goes to pin 2 of the switch the orange and green goes to pin one of switch and runs to the computer. from there the brakes are controlled by a solid state relay inside of the ECU
Oct 5, 2010 at 8:18 PM
