Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Stratus
Ignition
Coil
2002 Dodge Stratus ignition fire
2002 DODGE STRATUS
124,321 MILES • 4 CYL • FWD • AUTOMATIC
PISSEDOFFF123
MEMBER
1 POST
FOLLOW
Have no fire going to coil pack, pcm has low voltage codes. Pcm will not allow codes to be erased several codes low voltage. could pcm be bad?
Apr 14, 2010 at 7:21 AM
XSHAWN117X
MEMBER
Have you checked the voltage of your battery? The battery voltage readings when the car is off and cold should be between 12.5 and 12.8 volts.
If there isn't enough voltage across the ignition coil pack then there really isn't going to be any spark to the spark plugs.
Jun 3, 2010 at 5:10 AM
