2002 Dodge Stratus door locks will unlock but not lock
2002 DODGE STRATUS
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
NAGYGELLER
All of my power door locks on my Dodge Stratus will unlock when I use the master lock switch OR when I use the fob.
However, none of the locks will lock when I use the master lock switch or the fob. When I try to lock, they move a little and make a sound like they are trying to lock. But they do not lock. On some rare occasions they will lock, but not 90% of the time so I lock them by hand.
Any ideas what is causing this for all locks?
Nov 29, 2009 at 2:31 PM
BMRFIXIT
  • 19,053 POSTS
Check and suspect relays
Nov 30, 2009 at 9:12 PM
NAGYGELLER
relay has been replaced with no luck. Door panels have been removed and actuator and all conections and rods have been inspected.
Dec 1, 2009 at 6:51 AM
BMRFIXIT
  • 19,053 POSTS
If relays for sure was not the problem
next step would be checking BCM (body control module ) codes and
you need a scanner to do so
an OBDII reader will not help in getting the BCM codes and need to use a scanner
Dec 1, 2009 at 8:41 PM
