Hi sergio rodriguez,
Here are the diagrams for the accumulators.
P0732 is an intermittent code and are often caused by intermittent hydraulic seal leakages in clutch and/or accumulator circuits. they should be checked only under the condition when they are set.
Note :
A reset counter, located on Chrysler's Diagnostic Readout Box ( DRB_III) Scan tool, indicates the number of engine starts since DTC was set. This aids in determining if thDTC is hard or intermittent code. If reset counter shows less than 3 engine starts, it is a hard code. If reset counter shows 3 or more engine starts, an intermittent code exists.
Possible causes for the condition are :
1 . Low battery voltage.
2 . UD and 2-4 pressure less than 105 psi at 2000 rpm.
3 . UD pressure is less or greater than 5 psi in 4ht gear.
4 . Leaking transmission seals.
Coda can also be set byy intermittent input and/or output speed sensor circuit.
It is not going to be easy to diagnose this fault without the aid of appropriate diagnostic equipments.
Nov 1, 2009 at 9:30 AM
