2001 Dodge Stratus Speedometer
2001 DODGE STRATUS
141,000 MILES • 4 CYL • FWD • MANUAL
CDAW99
I have a 2001 Dodge Stratus and the clutch went out. I got the clutch replaced and when I got the vehicle back. The speedometer and mileage meter stopped working. The car runs fine.
Sep 28, 2010 at 6:16 PM
BLUELIGHTNIN6
  • 16,542 POSTS
press and hold the trip/odometer reset button while turning the ignition switch to OFF, then RUN position. this should cycle the gauges to do a self check. if the speedo and odo are not working after this than there may have been wiring left loose during previous repair such as the vehicle speed sensor (VSS) wiring.
Sep 28, 2010 at 6:21 PM
CDAW99
Where do I find the wiring for the VSS? I tried the reset suggestion but it did not work.
Sep 30, 2010 at 8:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
it will be on the right side of the transmission where the VSS mounts to tranny
Sep 30, 2010 at 8:13 PM
