2001 Dodge Stratus No Pwer at heater Switch
2001 DODGE STRATUS
59,000 MILES • 4 CYL • 2WD • AUTOMATIC
TWOODWARD
The heater blower motor not working is not working. Tested no power at switch. Checked fuses and all look fine. Is there a relay? if so what is its location?
Feb 2, 2009 at 1:04 PM
ZACKMAN
  • 4,202 POSTS
I don't see any relay in the wiring diagram. Just two fuses at the end of the dash, Fuses #1 and 11
Feb 3, 2009 at 11:34 PM
TWOODWARD
Check fuses, can you think of anything else that may be the cause of no power? I did read something about the contacts on the ignition switch can where out?
Feb 4, 2009 at 8:03 AM
ZACKMAN
  • 4,202 POSTS
Believe it or not, the power to the switch comes from fuse #1 to the blower motor, to the blower resistor, and grounds at the switch. Check continuity that way.
https://www.2carpros.com/forum/automotive_pictures/55316_01stratusac_1.jpg
Feb 5, 2009 at 1:25 AM
TWOODWARD
Thank you so much for the information. Is the junction box shown in the Diagram the fuse box? or is there another junciton bax some where?
Feb 5, 2009 at 12:14 PM
ZACKMAN
  • 4,202 POSTS
Yes, the junction block is the fuse box at the end of the driver dash.
Feb 5, 2009 at 7:10 PM
TWOODWARD
from looking at the diagram you sent the power come into the fan motor and the switch provides the ground? I really appreciate you help!
Feb 6, 2009 at 8:04 AM
ZACKMAN
  • 4,202 POSTS
You got it...
Feb 6, 2009 at 5:09 PM
