2000 Dodge Stratus struts
2000 DODGE STRATUS
109,000 MILES • 6 CYL • FWD • AUTOMATIC
YODOYO42
how do you replace rear struts
Aug 20, 2008 at 2:14 PM
BMRFIXIT
  • 19,053 POSTS
Removal
1. open trunk and roll back carpet covering strut tower. On all models, remove 2 nuts attaching upper strut mount to strut tower. Raise and support vehicle. Remove wheel assembly. Remove bolt attaching strut clevis bracket to knuckle. Push suspension downward and slide clevis bracket off knuckle. Remove strut assembly from vehicle. 2.Inspect strut for evidence of fluid leakage. Slight seepage is normal and does not require strut replacement. Remove spring. See COIL SPRING . Remove remaining components, noting order for installation reference.
Aug 20, 2008 at 2:52 PM
