After changing out the right/left wheel hubs(the noise was so bad it may have covered up this problem). I started to notice a the sound when leaving the driveway or any uneven surface. I changed out the the upper/lower Ball joints, CV shaft/joint(had a 2 small tears in the back of the boot behind the wheel Hub), Inner and Outer tie rod ends. Finally I disconnected the sway bar and removed it so I could rule that out. The upper control arm bushings looked fine. All the nuts on the shock tower are tight and I replace the upper bushing on the strut it self. Still the noise and feeling in the floor have not changed.
Not sure what else i can do at this time. Maybe the new wheel hub could be bad?? What are the chances??
Mar 15, 2010 at 10:26 AM
