2000 Dodge Stratus heat and smoke coming from rear wheel
2000 DODGE STRATUS
90,000 MILES • 4 CYL • FWD • AUTOMATIC
RONCO05
I have smoke coming from my rear wheel and the rim is really hot to the touch. I did the rear drum brakes about 6 months ago. Is it a wheel bearing that is gone? The wheel makes a grinding noise when i drive. Thanks.
Jun 20, 2009 at 11:36 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:15d9fe5e92="ronco05"]Tires and Wheels problem
2000 Dodge Stratus 4 cyl Front Wheel Drive Automatic 90000 miles
I have smoke coming from my rear wheel and the rim is really hot to the touch. I did the rear drum brakes about 6 months ago. Is it a wheel bearing that is gone? The wheel makes a grinding noise when i drive. Thanks.[/quote:15d9fe5e92]
Ok, when you did the brakes did you also change the Wheel Cylinders? If not could be that it is bad and locked shoes against drum.
Can you tell if the smoke has a brake or an oil smell?
If oil smell the yes most likely bearings.
If unable to determin then best course of action would be to take apart.
Jun 20, 2009 at 11:53 AM
