to sum it up, with vehicle on ground remove axle nut, then jack up vehicle, remove tire
remove tie rod, and disconnect upper and lower control arm from ball joint, remove pinch bolt on the steering knuckle and remove bearing assembly.
take it to a shop and have it pressed out and a new one pressed in.
Aug 1, 2008 at 9:13 AM
