1999 Dodge Stratus water pump
1999 DODGE STRATUS
AMANDALYNN147
Engine Cooling problem
1999 Dodge Stratus 4 cyl Wheel Drive Type unknown Automatic 113000 miles
where is my water pump and how do i put a new one on what do i need to take off on the engi
Mar 23, 2008 at 12:18 AM
SERVICE WRITER
  • 9,123 POSTS
Your going to need a manual for the r and r procedure and the specs needed for the job:
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Mar 23, 2008 at 6:56 AM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_24dodge__water_pump_1.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_24dodge_5.jpg
Engine stay in front right upper motor support need to be removed drive belt removed drain coolant remove timing cover and timing belt remove water pump bolts and remove water pump
Mar 23, 2008 at 4:58 PM
