The drawing most of the way down the page (G00256407) is the most relevant to my engine (the 2.4L is Dual Overhead Cam). My problem is that if I rotate the belt so that the right hand cam sprocket timing mark lines up in the middle, the left hand mark is not visible anywhere near the center. It is hard to tell exactly where it is, but it is somewhere on the far left hand side of the sprocket. If I rotate the belt until the left sprocket is pointing to the center, the right hand sprocket timing market is off on the far right.
If I understand this correctly, it takes two revolutions of the crankshaft sprocket to make one revolution of both camshaft sprockets. If I line up the pointer on the crankshaft, the right hand camshaft may not line up toward the center; but if I rotate the crankshaft one more revolution, the right hand camshaft mark will line up in the center. But the left hand mark never aligns with the right mark, no matter how many times I rotate the crankshaft.
As I said, this engine has never had any work done on it, so this has to be the way it came from the factory. It was running fine before I started this, and I haven't yet removed the timing belt so it is in the same alignment it had when it was running. I haven't tried to rotate the crankshaft counterclockwise because I know it can possibly cause the timing belt to jump a tooth. All my rotations have been clockwise.
If the camshafts were really as far out of alignment as they appear, I would think I would encounter resistance somewhere as things started colliding. But I can rotate it through the full cycle easily with just a 3/8" ratchet. So what it appears is that the timing marks are just meaningless as they are now (at least the one on the left hand cam sprocket). This would seem to be a factory mistake; and I'm just wondering if anyone has ever encountered a mistake like this.
I can take photos and send them if it will help make my situation clearer. Thank you for your help; this is the biggest job I have ever attempted, and I am taking it very slow to make sure I don't make any dumb mistakes. But knowing how important the timing alignment is, I'm concerned that there seems to be no way to correctly align these sprockets as they stand.
Jun 19, 2020 at 10:27 AM
(Merged)
