Engine stalls at idle
1999 DODGE STRATUS
98,600 MILES • 4 CYL • FWD • AUTOMATIC
RANDY HAYES
It runs fine when accelerating of going downhill but when you stop or running steady it tries to die like it wont idle
Jul 25, 2010 at 7:28 PM
Has the check engine light come on? Also, have you checked for vacuum leaks? This guide should help
https://www.2carpros.com/articles/stall-at-idle
Aug 7, 2010 at 12:49 AM
TLCKNIGHT1973
1997 dodge stratus keeps cutting off when comming to a stop, the check engine light does not come on
Aug 19, 2020 at 8:04 PM (Merged)
CARADIODOC
  • 34,306 POSTS
If the battery was recently disconnected or run dead, the Engine Computer has to relearn "minimum throttle" before it will know when it must be in control of idle speed. To meet the conditions for that to occur, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals.
caradiodoc
