1998 Dodge Stratus Right side rear view mirror was knocked
1998 DODGE STRATUS
221,000 MILES • 4 CYL • 2WD • MANUAL
HOWARDJ
This is a non-power mirror but has internal manual adjustment for mirror position. Windows are manual. No power door locks.
I have purchased the replacement mirror.
I am having trouble removing the inner panel on the door in order to gain access to the mounting screws for the mirror.
I am not sure how the window crank handle is removed---is it a clip or a screw? I am not sure what other challenges I may have after I remove that handle.
Can you guide me?
Thank you
Sep 18, 2008 at 6:39 AM
2CARPRO JACK
  • 11,533 POSTS
It is a c-clip on the back of the window crank, you can get the correct removal tool at just about any parts store. Look for pop in plugs that are hiding screws around the door handle/arm rest or behind speaker grilles. slide the door panel up to release the panel from the door. Just look carefully for screws before trying to remove the panel
Sep 18, 2008 at 7:46 AM
