1998 Dodge Stratus gages
1998 DODGE STRATUS
HADOOD
Electrical problem
1998 Dodge Stratus 4 cyl Front Wheel Drive 175000 miles
i lost my mph, tack, and heat gage, can you help please
Mar 1, 2010 at 10:17 AM
LEGITIMATE007
  • 5,121 POSTS
this usually means one of two things, either the connection in the back of the display is loose, or the body control module has one of its leads corroded or loose, over time,just riding over bumps can cause this, moisture will also cause corrosion, as you probably already know, so check these two things
Mar 1, 2010 at 2:24 PM
