1998 Dodge Stratus Battery and Alternator connections
1998 DODGE STRATUS
PHANTOM-PHYST
Electrical problem
1998 Dodge Stratus 4 cyl Wheel Drive Type unknown Automatic
I had my alternator rebuilt 3 months ago and my car died again.
so i put a new battery in three weeks ago it ran fine then the power started failing again.
I was told it could be a connection between the battery and the alternator.
can you help me???
Dec 29, 2007 at 9:54 AM
BMRFIXIT
  • 19,053 POSTS
You have to charge battery start car and check the voltage on the battery it should be above 14 volts with car running if not check with key on engine off check for a battery volts at the back of alternator
https://www.2carpros.com/forum/automotive_pictures/99387_ater_1.jpg
Jan 1, 2008 at 12:48 PM
