1997 Dodge Stratus oil leaking
1997 DODGE STRATUS
87,000 MILES • 4 CYL • FWD • AUTOMATIC
PATSYLOMAN58
i have changed the oil pan gasket twice and still leaks what am i not doing right
Feb 14, 2009 at 7:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Are you using proper torque on the bolts?
Tighten the oil pan attaching bolts to 105 inch lbs. (12 Nm).
Although no torque sequence is available, it is recommended that you begin at the center of each side and progress outward, in an alternating pattern.
Thanks for using 2CarPros.com!
Feb 14, 2009 at 7:59 PM
