i have changed the oil pan gasket twice and still leaks what am i not doing right
Feb 14, 2009 at 7:50 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Are you using proper torque on the bolts?
Tighten the oil pan attaching bolts to 105 inch lbs. (12 Nm).
Although no torque sequence is available, it is recommended that you begin at the center of each side and progress outward, in an alternating pattern.
