1996 Dodge Stratus starter or coil pack
1996 DODGE STRATUS
138,745 MILES • 4 CYL • 2WD • AUTOMATIC
CDOG0809
  • 16 POSTS
i went to start my car it turned over but acted like the battery was dead so i tried it again and nothing i tested the battery it was fully charged
i jumped it over from the starter it cranked over but would not start so i took off a spark plug wire stuck a screw driver inside metal to metal and cranked it from the starter no spark came from the wire i dont know what it is but every time i try to start it from inside i get nothing my dash lights come on but it don't crank or anything
Mar 3, 2010 at 10:02 PM
LEGITIMATE007
  • 5,121 POSTS
try to start it in neutral. also see if it will take a jump, keep me posted
Mar 3, 2010 at 10:09 PM
CDOG0809
  • 16 POSTS
i have already did both i put it in neutral and still nothing and i tried jumping the battery and nothing
Mar 3, 2010 at 10:33 PM
LEGITIMATE007
  • 5,121 POSTS
check the starter relay, in the power distribution center, check the asd relay too while your at it
Mar 3, 2010 at 10:37 PM
CDOG0809
  • 16 POSTS
the power distribution center is the black box under the hood right with all the fuses in it?
and where is the asd relay located and i do i check it?
Mar 3, 2010 at 10:54 PM
LEGITIMATE007
  • 5,121 POSTS
yes and the asd relay is in there too
Mar 4, 2010 at 7:02 AM
CDOG0809
  • 16 POSTS
ok i checked the starter relay and the asd and still nothing it still wont even crank from the inside
Mar 4, 2010 at 10:27 AM
CDOG0809
  • 16 POSTS
thanks for ur help i fixed it it was the fuel ignition starter fuse under the hood
Mar 4, 2010 at 11:12 AM
LEGITIMATE007
  • 5,121 POSTS
awesome, comeback anytime
Mar 4, 2010 at 12:27 PM
