Interior problem
1996 Dodge Stratus 4 cyl Two Wheel Drive Automatic
Yesterday I was getting gas, turned off the car but then turned the key to listen to the radio. As I did this the tac and speedometer arms went all the way around to the other side of the plastic pin that holds them at zero.
Now I have no speedometer (the tac I could care less about as it is automatic) because it is fighting against the pin to rise up as I accellerate.
Any suggestions? I was going to drill a hole in the dash where the pin is, bend or break the pin, move the arm and replace the pin. I will be the last owner of the vehicle so resale is not a worry.
Aug 21, 2008 at 12:52 PM
