1996 Dodge Stratus i need help
1996 DODGE STRATUS
SJHLEEDS86
Computer problem
1996 Dodge Stratus 6 cyl Front Wheel Drive Automatic unkown miles
i have a 96 dodge stratus and i have replaced the throttle sensor in it because it was not working properly now the car will crank on occasion and it will run but if you turn it off it takes atleast 5 hours before it will crank again any suggestions
Oct 1, 2009 at 6:08 PM
BMRFIXIT
  • 19,053 POSTS
Does not crank or it crank but no start
check TPS volts
what you have for volts and then step all the way down ion the gas paddle and check TPS volts what was the readings
Oct 1, 2009 at 6:22 PM
