1996 Dodge Stratus Engine Is Arking
1996 DODGE STRATUS
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARVIN SMITH
  • 6 POSTS
After my car is running for awhile (10) minutes, the engine will begin to "ark." I will stop at a light, the "RPM's" will being at 1100, and surge to 1300 before returning to 700. I can fell the car accellarating by itself, once my rpm's go over 1000. In addition, I must place my foot on the brakes, coming to a stop. I've changed the Termstat, Antifreeze, Oil, Oil Filter, Transmission Fuilds & Filter, spark plugs. What is the problem?
Mar 7, 2010 at 8:55 PM
BMRFIXIT
  • 19,053 POSTS
Do you have a check engine light on and if so you need to check for codes
suspect a vacuum leak and or an IAC valve
codes should pin point the problem
Mar 7, 2010 at 9:05 PM
MARVIN SMITH
  • 6 POSTS
[quote:cfe0b611c0="BMRFIXIT"]Do you have a check engine light on and if so you need to check for codes
codes should pin point the problem[/quote:cfe0b611c0]
Thanks for the advise. There is no engine light on in my vehicle. I brought the car afew weeks ago, and prior to my purchasing the car, it had been basically abandon. I did the few things stated as well as, added a brand new battery. The car failed a State Inspection, with the Inspector stating that "the cars computer hasn't readjusted after repairs." I was told to put a few hundred miles on it so that the computer can readjust and bring it back for my sticker. Nothing else is really wrong with the car, but that stated.
Mar 8, 2010 at 6:31 PM
BMRFIXIT
  • 19,053 POSTS
Its true need to drive 50 to 200 miles after replacing the battery
for the monitors to become ready , and to pass emission state test
since the battery was replaced computer need to relearn idle
best if you clean throttle body
Mar 8, 2010 at 7:12 PM
MARVIN SMITH
  • 6 POSTS
[quote:abfb8f682a="BMRFIXIT"]Its true need to drive 50 to 200 miles after replacing the battery
best if you clean throttle body[/quote:abfb8f682a]
Thanks so much for the information you have given me. I have just have one more question; "what is the throttle body,' "and where is it located?
Mar 9, 2010 at 4:50 PM
BMRFIXIT
  • 19,053 POSTS
this is on a V6 where air enter the engine
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_675.jpg
Mar 9, 2010 at 5:35 PM
MARVIN SMITH
  • 6 POSTS
Thank you again.
Mar 11, 2010 at 6:07 PM
