1996 Dodge Stratus Blower Motor fault?
1996 DODGE STRATUS
120,000 MILES • 4 CYL • 2WD • MANUAL
KIRANKHADKA
My A/C and Heat both works, but when I turn both to medium high and Highest, "Brrrrr" sound becomes unbeareably loud. Should I change blower motor? How to open to change it and if it's not Motor, what equipment do I require to check what's wrong. I am planning to do it on my own.
Oct 18, 2009 at 2:30 PM
IT sounds like the blower motor is bad. It is located beihind the glove box under the dash. I would start there. Chances are either something has come loose and is hitting the fan or the motor itself is going bad.
Let me know what you find.
Oct 19, 2009 at 8:33 PM
KIRANKHADKA
I went to Sears, Pepe Boys, both said over 130 to 250 respectively to solve the problem. I opend up and pulled out blower. Actually the car was sitting in garage for over year, so there was a mouse nest on fan filled with inside sofa stuff. I cleaned it and seems nothing was wrong. It's working fine now.
Thanks for your best technical support and guidance.
Nov 3, 2009 at 7:56 AM
I'm glad you found the problem. If you have questions in the future, let us know.
Nov 3, 2009 at 7:58 AM
