1996 Dodge Stratus
1996 DODGE STRATUS
365,000 MILES • 4 CYL • FWD • AUTOMATIC
LANDON L STEPHEN
my car does not run constantly for more than about a half hour. it runs fine untill then but shuts off by its self. i have replaced the temp sen. in the rad fill and changed the ign coil niether helped. also the stereo will not turn on, when the wires arc it wants to start the car. i changed this fuse and it immediatly blew, are these problems related? if so why? and how do i fix them? if not fixing the running problem is priority. please help me thank you Landon
Oct 1, 2010 at 11:57 AM
I don't think they are related. What is causing an arc with the stereo? Also, as far as the engine, has the check engine light come on? Have you checked fuel pressure? Finally, does it always start right back up or do you have to wait?
Oct 12, 2010 at 7:00 AM
