1995 Dodge Stratus
1995 DODGE STRATUS
110,000 MILES • 4 CYL • FWD • AUTOMATIC
HODGEY
the car will not turn over, the lights work the clock the odometer works the digital tranny selector works, but the clock does not work or the radio. the engine does even make a sound when you turn the key.
Dec 6, 2007 at 10:18 AM
CHEMICAL_ENGINEER
I had the same problem recently until the car just wouldnt start this morning..If you do find the problem please let me know
Jan 6, 2008 at 1:00 PM
I have seen the start motor go out on these cars, here is a guide to make sure. Use a test light to see if there is power at the starter terminal.
https://www.2carpros.com/articles/starter-not-working-repair
Here is the location of the starter so you can check it out and replace the unit is needed. Also you should check fuse # 8 in the fuse panel under the hood. I have included the starter wiring diagrams as well so you can see how the system works. Check out the images (below). Please let us know what happens.
Jul 5, 2024 at 11:36 AM
